JP
You don't say where in SoCal you're at, so here are some OC options & some out-of-state resources - then others can add in for LA, SD, IE, etc.
Talk to Ron at FAT Performsance in Orange OC, they've been building Type IV for race, Baja 500/1000 & street for decades, & he can give you a tour of his shop &
http://fatperformance.com/home/http://fatperformance.com/home/?page_id=51If you want to got further afield than SoCal.... or just for more info....
You can also contact McMark @ Original Customs - now back in Frostbite Falls
> see ads on the webpage top/bottom & as member vendor here
&/or Jake Raby - although I don't think he's building them anymore, but sells parts & kits -
http://www.aircooledtechnology.com/http://www.aircooledtechnology.com/index.php/porsche-914Note that FAT/Ron has been at this much longer than either of the above, Mark uses Raby Parts & IIRC is the only one still doing the Raby 2056 Kit builds, & IIRC Raby worked for FAT &/or one of their machine shops to learn the trade.
If you're further south, then Bill Brewster in South OC & AASE in Fullerton are also top notch shops for T4 & 914s - & aircooled Porsches in general.
http://brewsterporsche.com/http://aasemotors.com/I also know some 914 vintage racers & VeeDubbers who've used Der Buggy in Garden Grove to build their T4 race engines.
http://www.yelp.com/biz/der-buggy-shop-garden-groveA thought
.... you may want to pull & prep for & long term store the original 1.7 complete with the D-Jet & related parts - if it's numbers matching the car, which looks to be in excellent & collectible condition, & buy a "solid" long block 2.0L GA motor to do the bore/stroke/carbed build you mention, since the crank area was already worked by Porsche to get to 2L in the first place. So the 2L can accept more cc's more easily.
Also consider Megasuirt or one of the other "modern" aftermarket EFI's out there instead of carbs - unless you just happen to enjoy re-jetting & balancing carbs etc. in your spare time!
T4's can & have been built to 270 hp as far as I know, but that high is a short lived, hot running race engine - 150-180 is more realistic, but still may run a bit hotter & may not be great in traffic/DD/commuting.
Ron & the others can explain the trade-offs of it all to you, & builds them to all specs - as do the others. Raby's website has some good informative write-ups & HP/TQ charts on the various size kits/engines he sells/does/did as a good place to start reading up.
PS - another option is to put Euro heads on a 2.0 GA (73-74 engine) & tweak the D-jet & MPS etc. to take the stock Euro from 100 HP to a bit more TBD by bench testing. Porsche was notoriously conservative in rating their engines, so they more often than not turned out more HP than advertised - smog control BS on the CA market cars aside, & the GA in USA/CA or Euro flavor was no exception, as would be some conservative builds. IIRC the 2056 with D-jet can go as high as 125 HP IIRC.
PSS - Also heed what Jeff & I are saying about saving the car - especially now that I read that you're caretaking the car for your nephew, since even the lowly 1.7's will eventually be worth top dollar in the future in really nice unmolested shape, ergo save the engine if it's the original & mess with another, then the original can always be swapped back - if you don't hack or do mods that can't be undone easily.
Good Luck!
Tom
