So today I decided it was time to get to work on replacing the rear trunk floor and rear wall of my 1973. I have only had the parts for for oh....I guess about 10 years. Let me start by saying it was quite evident that it had been in a rear end collision when I bought it, but hey I only paid $800.00, it ran and besides it was a '73 2.0. So after watching everyone in here working on their cars I figured I had better get to it.
I figured I would start with the rear trunk wall and the rear trunk floor.
The PO took it to a shop and hell my 5 year old grandson could have doe a better job.
Of course poor workmanship led to leaks and the dreaded rust.
The job was so bad there was a quarter inch drop in the middle of the trunk wall. Caused damage to the hood as a result
And that is just the outside
Then I had to decide where I was going to start today. I had to assess the damage inside the trunk and then formulate a game plan...
There were so many poor welds (if that is what you want to call them) That it leaked so badly......
Someone drilled a drain hole in the trunk floor
And with that I decided to remove the rear wall first and then attack the floor
Once it was on the floor, I could really see the hack patch in the bottom center.Click to view attachment
So then I started cutting out the floor. I did it in sections since I was not sure what else the hackers might have done to it.
When I got to the passenger side and stripped all of the seam (hole) sealer the hack had put in there, this is what I found....
That gaping hole was filled with seam sealer. Guess it is going to be more work than I planned on for today.
Drivers side was not near as bad
Finally got everything cut out and cleaned up a bit
After several hours of work I was finally able to test fit the new floor, not bad for a days work considering how hacked up this car was.....Long way to go...
