Just venting my frustration over my now 2nd year of hunting for a Cayenne S!
That's including wasting the first 14+/- months trying to find a 2006 CayS Titanium Edition in that 6 month only "continuation model" Iceland Silver - a light silvery blue metallic, similar to my 85 BMW 325e's Cosmos Blue. After looking at 6-10 really nice appearing low mile 28-55k mile ones - none of which could confirm if they did or werre previously had them done by a PO for the dreaded V8 plastic to metal coolant pipe update! A few other high cost predicted failure items in the Sereis 1A (or 1) 03-06 version (headlight/composite units heat failures at a $1-2k per side to replace, rear hatch strut failures at $700+ every 2-3 years, etc.).
So we've moved on to the 2008-10 Series 1A (or 2) & maybe 2011-13 of the Series 2 (or 3A) Cayenne S, where we probably should've been in the first place due to the improvements.
Preferably one with both the factory tow hitch receiver & rear camera already installed - (the latter requires Nav/PCM to also be optioned), & preferably shod with 18" or 19" or 20" factory wheels (maybe factory 21") with proper N-Spec tires.
We're not too picky on interior colors - preferring Gray or Tan, but prefer to stay away from the darker Black & Brown due to both heat & showing too much dirt easily.
Now we're not overly picky on paint colors either, since we can accept the Blue, Silver, Dark Grey, & Gold/Jarama Metallic colors just fine & maybe even White - but not the other odd & cop-attracting colors (RED! & ORANGE!).
Black is NOT favored since it's such a PITA to keep clean & looking nice .... & our CayS will primarily be towing our restored vintage 1960 Avion T20 (#2 off the line - looks like an Airstream but better!) to vintage trailer events - so black will look cruddy all the time at those!
I feel like I'm back in the 19-teens & twenties looking at Ford Model T's - you know: "You can have any color, as long as it's black!" - as ole Henry I used to say!
I mean really - how friggin' many BLACK & BLACK-on-BLACK & BLACK-on-BLACK-with-BLACKOUT-Trim did Porsche have to make!?
Just not my taste all blacked out - but black with a tan interior & chrome/metal brightwork does look sharp to my eye - just not to keeping it clean!
Couldn't Porsche have offered/offer a CHOICE of decent colors!?
I thought I'd found "the perfect one" in a 2-owner 45,000 mile 2008 CayS in Marine Blue on Havanna/Sahara Biege Interior with the factory rear camera, but the DAPO had "improved" it with upsized non-factory 22" wheels & non-Porsche-spec tires - both of which rears had sidewall splits in them + the 4% speedo/odometer error....
.... Plus he had swapped out the excellent factory upgraded BOSE Audio/Nav/PCM for some supposedly "better" aftermarket unit - along with who knows what else was hacked-up on the harness since the rear camera now opend/closed every time a door opened or the key was turned - rather just opening when put in reverse & close when taken out!!!!
It was well cared for & maintained - but those above both prevented me from even taking a test drive (no blowouts on my dime!) nor considering it further without them all fixed (I could swap wheels/tires with another fool with a factory set later, & can get the factory tow hitch installed for $1200-2000 at a dealer).
A lesson for you folks - do NOT hack up your electrical harnesses with your "improvements" - especially not with the newer cars where all of the onboard computers, sensors, ECUs, Obi-wan-kanob-I's & -II's, etc. are linked together!
Nuff said....
Feel free to shoot me a PM or email if you hear of a likely 2008-12-ish Cayenne S candidate in our colors etc.! TIA!
Cheers!
Tom
