OK from Wayne's Book (pricing is 15 years old?), machine work you would do rebuilding a 2.7 but not on a 3.0.
$495 Line Bore
$350 Install Time Certs
$130 Oil system bypass mod
$29 Case saver inserts
=$1004, say *120% for today's prices = $1205
Looks like it is cheaper to rebuild a 2.7.
BTW His total was $3,300 for all the machine work (includes valvejob, rods and crank recon, etc...)
Total parts and tools was $2,872 which includes $1,400 for p&c's.
Grand total = $6200
This is a complete rebuild, only large purchase hard parts were the p&c's.
I'm going out on a limb here, but IMO there is vitually NO WAY you can do a "quality" rebuild of any 911 6 cylinder engine for $6200.
The prices in Wayne's book are very out of date.
Parts are much, much higher now.
Ever price a set of pistons & cylinders lately?
And easy $4-6k just there.
Depending on how
many parts are worn out, the picture just gets worse.
The big builders (i.e. Rothsport) will charge you $20k up to $30k to do a complete
engine rebuild.
There's a reason for that cost....and it's not all labor.
There is a lot of machining required, again quite expensive.
I think you're all kidding yourselves in this link.
Good condition, low mileage engines are rare as can be.
So now you're stuck with a rebuild on whatever condition engine you can fine.
To do a top end only is really a sketchy idea.
Add to this that most of us....even the mechanically adept....would be in over our heads with a 6 cylinder engine rebuild.
So much experience goes into the proper rebuild that the average guy is going to miss something during the process, and then you flushed a bunch of money down the drain.
Again all the above IMHO.
My takeaway.... rebuilding a 911 engine is not a trivial or inexpensive proposition, and not for the weak hearted.
But they are the best sounding automotive engine when done correctly bar none.
