I am in the midst of chasing why my hi beams inop condition. I have realized since the wiring was spliced in the pins might be incorrect in the 12pin connector. I have spent my whole Sunday and finally figured the pin were indeed in the wrong cavity. The solved that and now it triggers the relay I can get high beams.
The question is the gray spade wire on both sides of the column, I had it connected together but I am not sure if this is correct.
The left is bigger gauge with a plastic cover it while the left side is smaller gauge and old connector has been cut off. I have read the right side one is for key buzzer ?
So when does the buzzer come on and do I even want to re-connect that anyways.
I happen to have another igntion column but it was a 14 pin connector but at least I can use it for some reference and look what I see the similiar set of grey wires and they were connected.
Can someone educate me what these wires are for, are they supposed to connected where are they supposed to be connected to ??
Thanks in advance.
Ted
