76-914
Feb 26 2016, 01:38 PM
Decided to start another thread since I found the knock was from the shocks and not the torsion bars. When raised off the floor I have about 8mm slack vertically. A sudden lift upwards and this "Free space" allows for a knocking sound. I thought my shocks were not tightened down completely but they are.
Another thing; (again when elevated) the shock also has horizontal slop. If I push on it I can get it to move inwards towards the center of the car. is this normal? FWIW, these are new Bilstein's w/ ~6000 miles on them.
siverson
Feb 26 2016, 01:56 PM
That does not sound right to me... I don't think there is any slack or clunking once that top nut is tight.
-Steve
Elliot Cannon
Feb 26 2016, 02:04 PM
Is there a spacer of some kind that is missing? When you push up on the wheel, can you see the top of the shock moving? Is the threaded cap nut on the top of the shock barrel tight?
brant
Feb 26 2016, 02:26 PM
doesn't sound right to me either.
perhaps a shock has gone bad and now has a dead spot?
even new shocks can blow easily when they bottom out
back in the day, we used to have to replace the race car shocks annually, because we ran too low of a ride height on our old race car
that didn't leave adequate travel on the car
one big bump and without full range of travel, something has to give
I hope that's not your situation
but how low are you?
Larmo63
Feb 26 2016, 02:33 PM
Subaru power blew out your shocks?
No seriously, it sounds like you may not have the rubber bumper/buffer donuts in the shock tops? And, are your upper strut plates worn/broken?
These are usually pretty stout, even stock ones. The rubber in there is pretty indestructible. Are you missing the metal collars inside of the rubber?
Elliot Cannon
Feb 26 2016, 03:03 PM
Follow the arrow I drew in my trusty Haynes manual. Take the nut off the top of the shock. Push it down and pull the shock out. Lift the protective tube #25 off the shock and check to see if this threaded nut is loose. It will take a spanner wrench, or I used channel locks to tighten it. That's how I fixed my "clunking" sound. I have exhausted my entire knowledge (such as it is)of front shock absorbers. But then again I am not afflicted with the "SUBI CURSE".
r_towle
Feb 26 2016, 04:32 PM
I found that one of my shocks just died, so I can lift the wheel an inch or more which also creates a clunk when driving
Bartlett 914
Feb 26 2016, 04:37 PM
QUOTE(Elliot Cannon @ Feb 26 2016, 04:03 PM)
I had the same thing to me also. The top nut as Elliot described had backed off
76-914
Apr 19 2016, 09:07 AM
Still searching
. The nut on top is tight however when the shock is extended i.e., on the lift, I can push sideways on the shock and I hear what I believe is
THE noise. Then I remembered that when I replaced the shocks a while back, one had this rubber sleeve (pn# 00454002871) and the other had none. Should each shock have one of these even though I have Bilstein's now? PET says BOGE in the discription??? TIA, Kent
r_towle
Apr 19 2016, 01:39 PM
Rubber sleeve on bottom of insert to hold bottom in the middle and prevent th clunk? That one?
Rich
SLITS
Apr 19 2016, 01:52 PM
QUOTE(76-914 @ Apr 19 2016, 08:07 AM)
Still searching
If you're talking about #26 in Ellyot's diagram, the answer is yes. It supposedly keeps the shock from bottoming out. Bottoming the shock is BAD as Bernat said.
76-914
Apr 19 2016, 02:31 PM
QUOTE(SLITS @ Apr 19 2016, 12:52 PM)
Still searching
That's it. Great news Thx Ron. Now I just need to locate one more "rubber spring" as they are called and 2 tapered bolts to repair. If that takes care of the noise I will only have the noise from the urethane bushings on the trailing arms.
Those will be shit canned before Christmas. Maybe go needle bearing back in here next time. Thx again.
76-914
Apr 19 2016, 02:32 PM
Still searching
DCJosh
Apr 19 2016, 03:30 PM
My front suspension is completely shot. Where do I begin when looking for the correct parts to replace the sagging. Pelican has strut inserts with what look to have the sleeve on them and then has strut inserts that do not have the sleeves which are significantly less expensive.
I don't want to thread hi-jack, but this is the closest thread I have seen which kind of relates to my problem.
Josh
76-914
Apr 19 2016, 04:59 PM
QUOTE(DCJosh @ Apr 19 2016, 02:30 PM)
Josh
That's cool. Pelican, PMB, G&R, Eklers, Sierra Madre. Spend some time with whomever you select to insure you are purchasing OEM replacement part and not some cheap Chinese POS that will last 12 mo's or one Auto-X outing!
SLITS
Apr 19 2016, 07:39 PM
Josh
First, buy a Haynes Manual to look at the procedure for setting front axle ride height. If the torsion bars are not worn out, you can adjust it.
As far as front inserts (shocks), I have never seen any with bushings on the barrel to fit a 914.
Other problems are the rubber bushings in the control arm, but that's for another time.
Elliot Cannon
Apr 19 2016, 08:17 PM
Two words: Subie Curse.
DCJosh
Apr 19 2016, 09:43 PM
QUOTE(SLITS @ Apr 19 2016, 08:39 PM)
I have a Haynes, I'll check it out. If I can not adjust, do I assume it is the torsion bars?
I just priced them on Pelican, I hope its not the torsion bars! Yikes!
SLITS
Apr 19 2016, 09:54 PM
QUOTE(DCJosh @ Apr 19 2016, 08:43 PM)
You can get them used in the classifieds. Be aware, they are marked Right and Left.
Larmo63
Apr 19 2016, 10:11 PM
The front suspension on a 914 Porsche is actually really a simple affair. Adjusting it and building it CORRECTLY is the trick.
It is about assembling with correct angles and adjustments, along with the correct parts assortment.
Good luck, it can be challenging, even for those who know what they are doing.
6freak
Apr 20 2016, 09:15 AM
you knew that yet you installed them anyway ? I gotta ask why you would do that
DC you dont adjust the front axle ride hight with the torsion bars ,axle dont go up and down the car body does
have fun
76-914
Apr 20 2016, 09:19 AM
QUOTE(6freak @ Apr 20 2016, 08:15 AM)
Ignorance. Did you think there was any other reason? Why the Hell else would I have done it?
6freak
Apr 20 2016, 09:25 AM
Hahaha OK you learn by your mistakes!
good luck
MikeC
76-914
Apr 23 2016, 07:43 PM
Krieger
Apr 23 2016, 11:30 PM
Wow...Not good
76-914
Apr 24 2016, 08:05 AM
Looking back, I should have torn it down earlier but my thinking was "It's all new, so that can't be it"! Whereas it should have been, "Who installed this stuff"?
Anyway, it's all good now and finally quiet sans those damned urethane bushings on the trailing arms. I see needle bearings in the near future.
ChrisFoley
Apr 24 2016, 12:06 PM
QUOTE(Elliot Cannon @ Feb 26 2016, 04:04 PM)
76-914
Apr 24 2016, 01:06 PM
Yep, totally misconstrued that to be the lock nut on top.
Larmo63
Apr 24 2016, 01:48 PM
Fart smeller……………………..I mean, Smart feller……
