QUOTE(bigkensteele @ Mar 3 2016, 02:43 AM)
Hello, May.
Your leak is nothing serious. There is a gasket between the metal tank and the plastic filler neck that has most likely failed. This is very easy to replace.
However, I notice that your hoses appear to be original. This may or may not be a problem, depending on their condition, but it would indicate to me that the car may be in need of other maintenance items. It is 43 years old now, and it should have the plastic fuel lines that run inside the tunnel from the tank to the engine bay replaced with stainless steel. The plastic lines are known to crack with age.
We have at least two other members here from Sweden who really know these cars (Falcor75 and DavidSweden). I am certain that one or both of them would love to help you sort out your inheritance.
Nice to have you here!
(Hehe, I've just learnt not to delete the text that I'm responding to...)
Oh, thanks!!
You really made my day! I was prepared to hear the worst..
Yes, it's true that the car is original and most of the fuel lines are original ones too... Won't leave the garage until all of them are changed though.
I'm searching for the best option amongst stainsteel armoured fuel lines. Do you know which label is to prefer? Is stainsteel lines a better choice than copper lines for the centre tunnel?
She is turning 43 yrs this month and will celebrate with new filters and fluids. Are there more than 3 filters to change (fuel, oil and air)? I even found a square fuel filter from Mahle, so I'm super happy
And once again, Thanks for your help
//May
