I'm having an m10 stroker built for my BMW 2002 and when we pulled the engine the bay was such a mess I decided to strip it back to bare metal and repaint it myself.
This is the first time I've painted anything, but I prepped the crap out of it, did my research and took my time, and it was going really well, until I ran out of basecoat...
So far I've sprayed 2K epoxy and 2K high build primer, but the high build was a dark gray and it took me way more base than I expected to get coverage.
The picture is where it's at right now. I have more base (1K urethane) on order but it's going to be a couple of weeks before I can get back to it. So, my question is, given the amount of time between coats of base will I need to scuff up the base again before spraying the next coat?
Also, will it be okay to clean the base with prep solvent before I spray the next coat? The tech sheet says not to, but given the fact it's going to be sitting in my friend's shop for 2 weeks I feel like I'm going to have to clean it with something to ensure no contaminants have settled on it.
John
