Allan
Mar 25 2005, 08:30 AM
Now it's time for a speedo cable question. Started to replace my speedo cable last night along with all the others. It's way too long. Must be for the pre-Cat/EGR counter. Is it possible to bypass the counter and go directly from the tranny to the speedometer?
scotty914
Mar 25 2005, 08:32 AM
you mean you have not done that already
Allan
Mar 25 2005, 08:37 AM
No, not yet. I wanted to make sure it would work first.
skline
Mar 25 2005, 09:50 AM
It does work, you will no longer need the little box under the passenger floorboard. Just run the cable from the trans to teh speedo and be done with it. I thought Aaron was going to do those for you?
Allan
Mar 25 2005, 09:56 AM
I think I'll just use the speedo cable like you said and eliminate the box. I'd like to pull it out of the car but I'm sure you have to re-wire something. Aaron didn't answer on the offer this weekend of beer and gas but he might end up doing the clutch cable next weekend if I can find the right one that fits.
