QUOTE(matthepcat @ Mar 24 2016, 10:01 PM)
The 5MT is too long with the tail cone removed and a bremar sleeve installed?
http://www.bremarauto.com/products/subaru-...conversion-kit/Can't image it would be any longer than Boxster.
Some Suby conversion guys could take a measurement here on the board for you.
It is longer by inches. Enough that I could see issues, it has made me think about a Audi/Boxster unit a lot, not doing it. Unless I go with an audi/Porsche engine.
So if Precision is not doing the adapters anymore did you ask what it would cost for the File? Get them CNCed up, and you have your adapter. In reality it would be $$$$ unless you have access to CNC gear. But if you really want it, then I say go for it.
Did you try Kennedy? they do an LS to Audi Kit, they have the patterns they might be able to work this on out for you.
In reality I would try to make the 5MT work, cheap, bolts right up, lots of clutch choices, tons of knowledge, and 1000s of rations, and numbers LSDs. All very good for what you are doing. And if you get a generation 2 unit, you can lay lots of power to the trans.
