9fourteen14
Mar 30 2016, 05:02 PM
I would like to remove my dashpad top? 74 2.0
does 914world have a thread with how to's for this?
if not has anyone done it? if not any tips?
thanx 914 luva
76-914
Mar 30 2016, 05:29 PM
Yes it does.
Larmo63
Mar 30 2016, 05:36 PM
There are quite a few threads concerning this. It isn't all that fun to do, but once you've done one, it's not all that hard.
Dave_Darling
Mar 30 2016, 10:42 PM
Check in the "classic threads" section.
--DD
sb914
Mar 31 2016, 06:19 AM
GaroldShaffer
Mar 31 2016, 06:35 AM
QUOTE(Dave_Darling @ Mar 30 2016, 11:42 PM)
--DD
Click this link ----->
Click Here
screenguy914
Mar 31 2016, 11:02 AM
iankarr
Mar 31 2016, 11:23 AM
Once the dash top is off (lots o' existing threads on this), the dash frame itself can be removed by unbolting the 2 screws on each "door" side. There's also a bolt connecting an extension of the dash to the frame under the steering column. And the 4 nuts under the cowl. To access those cowl nuts you need to remove the plastic defrost/vent pieces and contort your arm with a small ratchet. Easier if the gas tank is out...but totally doable with it in.
sb914
Apr 1 2016, 06:16 AM
