freezing14
Mar 30 2005, 08:11 AM
Got some bugs with the high/low system,, they do not seem to work , the relay that does the switch seems to be dead,, but everytime i see one listed it looks different, the all list it under headlight relay but it has 5 pins instead of 4, do any one know if the flap can have it and if they can who do they get it from and what is the part #
thanks
double-a
Mar 30 2005, 09:01 AM
search the archives, this subject has been discussed before, with pictures even. you can use the new relays without any problems, they operate the same as the oem ones. but you'll need to fashion a jumper wire from pin 30 to pin 56, if memory serves.
~a
freezing14
Mar 30 2005, 09:49 AM
I found only one
http://www.914world.com/bbs2/index.php?act=...21750&hl=dimmerso apparently the other one will work OK,, I will order it at my flaps,,
thanks guy
double-a
Mar 30 2005, 09:57 AM
no prob. try this one:
headlight flasher relaylook a few posts from the top for the image. the reason i remember is that i had the same problem, and posted a pic of the new relay with the jumper attached. ignore the other wires on pin 56, those are for the fog light flasher kit available from jwest.
~a
