I have a 12v battery. I hook 1 horn up and to BLOWS. Same with the other. Black to black to battery and white to white to battery and they just rumble. NO BLOW. hoq should i test wire?
messix
Apr 17 2016, 11:56 AM
QUOTE(malcolm2 @ Apr 17 2016, 07:58 AM)
2 wires per horn.
weak battery?
Rand
Apr 17 2016, 02:22 PM
Are you connecting series or parallel? Troy, I just had a funny image of a 12v battery with the amps to power a toy. Tell us about the battery?
malcolm2
Apr 17 2016, 02:54 PM
I guess it could be the amps. It is a 12v drill battery.
messix
Apr 17 2016, 04:06 PM
ok um ya ..... a car horn draws up to about 10 amps
ever notice that the horn circuit has a big fuse?
Valy
Apr 17 2016, 09:52 PM
QUOTE(malcolm2 @ Apr 17 2016, 01:54 PM)
Well.... when I.suspect that the battery is dead I try to blow the horn. This test never fails. The horn is one of the most power demanding things in the car.
malcolm2
Apr 18 2016, 07:42 AM
So today the test moves from the bench to the watercooled VW, close to the bench. I'll use that battery.
Thanks gentlemen.
malcolm2
Apr 18 2016, 04:45 PM
That was it. They are plenty LOUD. next time i take my bumper off, the new horns go on.
TheCabinetmaker
Apr 18 2016, 05:03 PM
If I remember correctly, the horns can be changed thru the fog light openings.
