jack20
Apr 20 2016, 06:39 PM
Something I thought would be a no-brainier has turned into frustration. I'm reinstalling the tins, heat exchangers and ducting and ran into a fit problem. Doesn't seem that others have had the problem because my research came up empty.
What is the sequence of installation? Heat exchanger first or the duct piece first?
Thanks, Jack
This piece:
TheCabinetmaker
Apr 20 2016, 07:03 PM
Jack, heat exchangers first, then the piece in your pic, then the j tube, then branch tube, then heater valve. It can be tricky, but it will go. Don't forget the small flaps that hang from the fan shroud openings.
Btw, your
shims were taken to the post office this afternoon.
jack20
Apr 20 2016, 11:20 PM
Thanks very much Curt!
SA-914
Apr 22 2016, 01:16 PM
What do the flaps do? Mine are missing.
Also, my square duct covers don't fit very well?
Dave_Darling
Apr 22 2016, 09:36 PM
The flaps will keep the aux blower fan from pushing air from the exchanger back into the fan shroud.
The square covers, if I understand what you mean, are unique from side to side. Try swapping them and see if they fit better.
--DD
barefoot
Apr 23 2016, 04:39 AM
QUOTE(Dave_Darling @ Apr 22 2016, 11:36 PM)
--DD
If you're not using the aux heater blower, then these little flappers are not needed.
Well, that's my plan anyway.
rgalla9146
Apr 23 2016, 05:15 AM
Before installing, do a trial fit of all the parts on the bench.
Especially the tubes and valves.
Make certain the tubes can properly enter the valves.
Gunn1
Apr 23 2016, 05:49 AM
Is the aux blower feature really needed?
BeatNavy
Apr 23 2016, 05:53 AM
No, not really. It's real purpose is to force air through the HE's when the engine speed isn't high enough to do so (e.g., while idling). If you don't put the aux blower on then it's been recommended you cap the J-tubes on each left/right engine shelf to prevent hot air making it's way up into the engine bay. That's they way I'm running right now.
rhodyguy
Apr 23 2016, 06:47 AM
Plus, lack of the 2 doors on the shroud and uncapped j tubes makes for poor heating. REALLY poor. The heat system delivers when the design components are serviceable and in place.
SA-914
Apr 23 2016, 06:50 AM
Would you get better engine cooling by blocking the fan shroud flaps, and just relying on the aux blower for all the air, and using the motor fan just for motor cooling?
Amphicar770
Apr 24 2016, 08:52 AM
Take lots of pics and notes. I am a few steps behind you. :-)
