Shindog1961
Apr 25 2016, 10:31 AM
Right after getting my 914 back I started to have to push the clutch as far as possible to get it into 1st and reverse without it grinding. Not as bad in 2-5. I'm thinking it needs a clutch adjustment. I've never done one on any car, can I tackle it myself? I'm pretty handy if I have some instructions, but there are none in either of the 914 manuals I have. Any advise, instructions? Thanks
Shindog1961
Apr 25 2016, 12:06 PM
Never mind. Literally the faster repair I've ever done. Less than 10 minutes. I hope I never paid to have it done
Planedoc
May 15 2016, 10:05 PM
im having the same issue, what was your fix?
r_towle
May 15 2016, 10:07 PM
Clutch cable has an adjustment nut on the end
Look underneath the car, passenger side.
Planedoc
May 16 2016, 07:57 AM
Thanks i know exactly what your talking about
jim_hoyland
May 16 2016, 03:37 PM
While adjusting the nut on the end of the clutch cable, check the cable where it rubs against that wheel at the rear. This is where most clutch cables break. It may be due to abrasion from particles getting into the strands of the cable; a little grease and short quick movements assist in the process
So..now when I adjust the clutch cable, I'll back the nut(s) all the way off and pull the cable back to expose the part the cable rubs against; wipe the wheel and cable clean and reinstall the caable.
Cause one clutch cable failure early using this method.
Planedoc
May 16 2016, 04:23 PM
Jim , so your saying it's ok to apply a little grease to the cable. I was under the impression that clean and dry is better so I doesn't attract dirt
Mikey914
May 16 2016, 04:36 PM
If you have the clutch cable rubber boot , you should lubricate it. If not I wouldn't because it will collect dirt
jim_hoyland
May 16 2016, 05:15 PM
QUOTE(Planedoc @ May 16 2016, 03:23 PM)
I meant to say wipe the dirt and grease off the cable; some recommend oiling the cable; main thing is to get it clean and dirt removed
Planedoc
May 16 2016, 06:59 PM
Ok thanks guys very much for the advise
