gisound
May 2 2016, 09:26 AM
Can someone point me to a thread that shows repairing the pedal box area? Finally pulled my 914 out of storage where its been for the last 10+ years to start the repairs that made me put it away all those years ago! I'm 47 now and have owned this car since I was bitten by the bug at 13! Time to get her back on the road! Still got all the other typical southern rust to take care of. Passenger long, lower firewall, rear trunk area, drivers jack post area, etc., etc, etc, This site and its members are truly inspirational and in invaluable wealth of experience and knowledge!
Thanks,
Blair
BeatNavy
May 2 2016, 01:43 PM
You may want to post pictures of what you're trying to repair. The floor plan under the pedal cluster? The bulkhead where the master cylinder meets the pedal cluster? The pedal cluster itself? I don't know a thread off the top of my head that shows fixing the floor pan where the pedal cluster bracket is, but with enough digging (and/or someone's help) I'm sure one can be found.
I just got through replacing that whole area. The floor pan is completely new, but I had to fab the section where the master cylinder connects to that section of the floor plan. I could provide a picture if that would help.
gisound
May 2 2016, 01:48 PM
If you have a picture that you could share that would be very helpful. I havent gotten in there to take it apart an see exactly whats going on but I do know the pedal assembly is VERY loose where it attaches (or used to attach) to the floor. So there will be pan work I know. Just trying to see what else may be involved.
Thanks again!
DavidSweden
May 2 2016, 01:53 PM
QUOTE(BeatNavy @ May 2 2016, 11:43 AM)
If you have the time please Post some pictures I have the same issue and need some help
Thanks
BeatNavy
May 2 2016, 02:24 PM
Ok, here's the reader's digest view of my front floor pan area repair (what it looked like before and after).
Here's the PO's attempt at fiberglass repairing what was left of the pedal cluster bracket on bottom of the floor pan. You can see the mess of sticky black stuff just below the tunnel outline (driver's side below tunnel in this view, obviously). I'd say that repair was very well done
Click to view attachmentAnd here's what was left of the metal at the master cylinder bulkhead after I removed the "repair." There was really no metal left. Nope, no safety issues here:
Click to view attachmentI purchased the entire floor pan from Reston Design. The only problem is, it ends about where that yellow line is spray painted in the picture above. Everything forward of that had to be fabricated or repaired. Fabricating the master cylinder piece was tough for me because a) it's a complex shape, and b) I suck at this. Here it is with the new front floor pan and the master cylinder mount.
Click to view attachmentI "reconditioned" the other large complex piece of metal forward of the floor pan, and fabbed one other small piece. The large complex piece is not in great shape, but I think I reconditioned it to the point where it will work. Here's the semi-finished piece prior to welding on the pedal cluster bracket (bottom picture) which I did this weekend (but don't have a picture yet). That bracket is part of the floor pan kit from Resto Design. I think it looks slightly better than the black blob of goo that was on there before.
Click to view attachmentClick to view attachmentIf you need another angle or picture, let me know. The car is still vertical and will be for a little while longer.
DavidSweden
May 2 2016, 02:42 PM
Thanks for posting the pictures. It looks like the the same problem if not a little worse than my car.
I will give it a go...... it will be fun
gisound
May 2 2016, 02:50 PM
Thanks! Thats exactly what I thought! Looks like I'm in for a lot of the same repairs. On the drivers side at least. Didnt think there would be a pre made piece for the forward area where the master cyl. mounts. Looks like its time to break out the hammer and slide rule!
Thanks again,
Blair
somd914
May 2 2016, 04:21 PM
I suffer the same fate in my silver car - rest of the floor is solid thankfully. Agree, I haven't found an aftermarket panel, so it took a while, but was able to get the panel cut from a parts car thanks to a fellow World member. Now to do the work...
Also, give Restoration Design a call. I had talked to them one time about this, and though they don't make the panel, they offered to look for a parts car to cut one from. Plus, if enough people inquire, perhaps they'll start manufacturing them...
ThePaintedMan
May 2 2016, 04:49 PM
I don't have any good pictures of how we did it, other than to use the support bracket and pedal cluster as a sort of template to get an idea of how to transition the metal from the floor pan to the vertical master cylinder piece. Then I carved out a wooden "buck" of sorts to hammer the shape into the repair metal. Then, just welded it in. As long as you're careful to make sure that the bolt holes for the M/C and pedal cluster all line up as you go, you'll be fine.
BeatNavy
QUOTE(somd914 @ May 2 2016, 06:21 PM)
It's good you had access to a parts car. It would have been preferable to use a solid donor piece.
Good idea about calling Restoration Design, as well, either for donor or for a fabbed piece. I think I recall a few months ago that they were planning on adding more metal pieces to their catalog.
somd914
May 2 2016, 07:05 PM
QUOTE(BeatNavy @ May 2 2016, 06:49 PM)
We still need to do the work, on our schedule for this summer once it gets hot and humid and don't won't to drive the teener...
Nice write up by the way, thanks for sharing.
cary
May 3 2016, 08:40 AM
QUOTE(ThePaintedMan @ May 2 2016, 03:49 PM)
Most important and hardest part.
BeatNavy
May 3 2016, 08:54 AM
QUOTE(cary @ May 3 2016, 10:40 AM)
I think I test fit everything 10 times. Even then the bolt holes for the bracket weren't perfectly lined up. I needed to adjust them slightly. I had the pedal cluster bolted in with the bracket and the MC attached before I actually welded the bracket to the floor pan.
Jonathan Livesay
May 3 2016, 09:20 AM
I have seen that area rusted out on a number of cars now, brake fluid from a leaking MC is likely the culprit. It might be a good piece for Restoration Design to make next.
malcolm2
May 3 2016, 09:32 AM
QUOTE(BeatNavy @ May 2 2016, 03:24 PM)
Does anyone know why this piece has the hole in the front? the way it mounts it becomes a little tow loop, if you are so inclined. Seems weird and I know the Germans had a reason for it.
BeatNavy
May 3 2016, 02:05 PM
I asked this in a separate thread a few days ago. Consensus from more experienced hands than me was that the loop serves no real purpose, German engineering aside.
marksteinhilber
May 3 2016, 02:38 PM
I rep[aired mine recently with one small insert near gas pedal and three doublers on the outside or bottom that make the pan stronger than original. A resto Design part then goes on the outside to attachj the pedal assembly and to fasten the gas pedal to. The hole or ring seems to be a drain for the front floor pan.
Click to view attachment Click to view attachmentClick to view attachment
marksteinhilber
May 3 2016, 02:42 PM
marksteinhilber
May 3 2016, 02:46 PM
Paint and reinstall pedals. Hope to get some Bruce D Stone rebuilt pedals at some point.
