QUOTE(ash00 @ May 6 2016, 05:45 PM)
Yes, sorry for the confusion..just for the tins and inspection of the flaps. I tried to use a scope through the hole but it still wasn't clear
Another shot in the dark, but if there is no shaft, how would you couple the flaps? The previous owner said they were "permanently" closed. I don't know if you can just put them in there loosely without any connection.
Oh sorry.
Yes you can remove the passenger side engine tin with the engine in.
It's a PITA and you have to manhandle the front tin a little, remove the intake manifold and the distributor. Some of the wire harness goes through that tin as well, but if you just want to look under, you wouldnt have to pull those wires out.
And I found the shaft with the drivers side flap attached, the passenger side flap, and two thermostat brackets, the pulley and maybe a intact piece of cable.
I think the only thing I am missing is the little arm that connects the shaft to the pass. side flap. Still looking.
