ash00
May 2 2016, 12:15 PM
Hi All,
After a month and a half of business trips, I finally got to drive my the 1970 914 that I'm still learning about.
One thing is clear, that the restoration was half-assed, and rather than blaming the PO, I have to figure things out the hard way. Hopefully before the fact. I'm trying to not let this leave a bad taste in my mouth of the 914 experience.
The recent issue is overheating. This is my first car in the aircooled world, and the car was equipped with a rebuilt 2.0L with the weber downdraft setup in place of the FI. It runs well when warmed up, but during driving, I can't drive it for more than 10 minutes without the gauge being pegged to the red. I'm hearing things of "false air" and such.
Pardon my ignorance, but I need a place to start looking for info. Is there any documentation or info out there on how the air cooling is managed, and what hardware is there for me to test / check? Any tips are appreciated.
Thanks,
Ash
Porschef
May 2 2016, 01:18 PM
Hey Ash,
You might want to check the gauge for accuracy first, then make sure there's no mouse nests/ obstructions in the cooling fins and that the flaps are operating properly. Also, that the oil cooler has air flow.
I have a kitchen thermometer with a long probe; something like that might be able to tell you how hot your oil is by putting it down the dipstick tube.
If you're over say, 220-230, then there's other issues at stake.
Good luck.
ash00
May 2 2016, 01:29 PM
Great Idea. i have a fluke with a TC. I'll try that out. I'll first check at startup, idle for a few minutes, then driving for a bit and seeing what it is at halfway, then 3/4 then at red.
injunmort
May 2 2016, 01:35 PM
after checking what joe suggested, i would first check the timing. then check jetting in the carbs. i would not drive it until you get a handle on this problem, if the gauge is right and timing and jetting is off, you can easily hole a piston.
ash00
May 2 2016, 01:37 PM
Definitely.
What should timing be set at?
injunmort
May 2 2016, 01:44 PM
34 degreess btdc fully advanced. good tech article on pelican parts site on the procedure.
May 2 2016, 02:25 PM
Also make sure your cooling flaps are installed and operating correctly.
There is a LOT of misinformation about those floating around and i have even seen "rebuild" engines where they had been removed completely.
injunmort
May 2 2016, 02:28 PM
i had a rebuilt engine in my dd that had the flaps removed. needless to say i replaced it over the winter.
brant
May 2 2016, 02:59 PM
top of my head.... I thought factory timing was supposed to be 27degree's
usually on a carb'd car with any cam in it... slightly higher than stock is good for power
especially at altitude
but sea level, maybe not so much
injunmort
May 2 2016, 03:16 PM
i think 27 degrees is for stock distributor advance fi. i did mine according pelican with stock cam and new dist. at 34, weber 40's and it runs about as well as it can with the cam/carb combo. did not like 27 degrees at all.
era vulgaris
May 2 2016, 03:33 PM
Since this is your first air cooled car, let me ask what RPM do you typically cruise at?
If the answer isn't between 3k and 4k rpm, then you're doing it wrong. The cooling fan is bolted to the crankshaft, so in order to get enough cooling air moving, you need to cruise at higher rpm than a water-cooled car.
Also, there's a valve (can't remember what it's called - oil pressure relief/oil pressure release...something like that) that allows oil to bypass the oil cooler when cold to aid in warm up. Over time it can get worn out and not allow enough flow to the oil cooler when the engine is warm.
Also, just FYI, the temp gauge only measures oil temp. Not sure what you mean by "false air".
ash00
May 3 2016, 11:34 AM
I appreciate all the help guys! Looks like I'll have to do some digging. I have to find what the flaps look like and see if I do have them.
I'll have to run the temp test on the oil. If that is the oil temp I'm reading, then I have to see what is restricting or causing it to get hot quicker than normal.
Any links or pictures as to what the cooling flaps are supposed to look like so I can compare?
May 3 2016, 11:58 AM
QUOTE(ash00 @ May 3 2016, 10:34 AM)
This should help:
http://www.914world.com/bbs2/index.php?s=&...t&p=1732173
era vulgaris
May 3 2016, 12:09 PM
You won't be able to see the actual flaps as they're under the cooling tin. But you will be able to see the bar that links both flaps together. It'll run across the engine behind the oil filler tower. You can see it in the pics SirAndy linked to.
If you do have the cooling flaps installed, then you should also check to see if you have the thermostatic bellows that operates them. The thermostat is kind of below the pushrod tubes on the drivers side, it looks like a set of bellows, and there should be a wire that runs from it up through the cooling tins and connects to that crossbar that the flaps are attached to.
ash00
May 3 2016, 02:23 PM
Awesome- that helps.
I assume that the flaps are actuated from red lever by the shifter?
ChrisFoley
May 3 2016, 02:37 PM
QUOTE(ash00 @ May 3 2016, 04:23 PM)
No, the flaps are automatic.
The red lever opens the flappers on the heat exchangers to move heat into the cabin.
era vulgaris
May 3 2016, 04:41 PM
No, as I mentioned, the flaps are actuated by the thermostatic bellows, which is attached to the lower part of the engine on the driver's side, kind of below the pushrod tubes. The bellows open and close with the heat of the engine, closing the flaps when the engine is cold and opening them when it is warm. This process is completely autonomous of any input from you.
If your thermostat is missing or broken, or if the cable from the thermostat to the flaps is broken, the flaps automatically default to the open position to prevent overheating of both the cylinder heads and the oil, as the flaps deflect cooling air to the cylinder heads and the oil cooler. That's why it's necessary that you have flaps if you have the stock oil cooler, because without them cooling air will not be directed toward your oil cooler.
Elliot Cannon
May 3 2016, 05:18 PM
QUOTE(SirAndy @ May 2 2016, 01:25 PM)
My flaps aren't removed but are locked in the full cool position. It just takes a little longer to warm the engine up. "Full cool". I like that.
r_towle
May 3 2016, 05:22 PM
QUOTE(Elliot Cannon @ May 3 2016, 07:18 PM)
Super cool
boxsterfan
May 4 2016, 09:55 AM
QUOTE(Elliot Cannon @ May 3 2016, 04:18 PM)
Yep, my understanding is that it is better to have them in the default open "cool" position then none at all. Just a little longer warm-up time as you mention...
ash00
May 4 2016, 10:23 AM
Well, I had a chance to head to the shop and check out the engine bay. No rod between the engine, as shown from the pictures from the link. I can only assume that the flaps are removed, but I have to figure out a way to remove the shroud and check.
I think I need to look into an aftermarket oil cooler as well
May 4 2016, 11:14 AM
QUOTE(ash00 @ May 4 2016, 09:23 AM)
The good news is that you probably found your overheating problem.
The bad news is that you'll have to get up close and personal with your car to fix it. You'll have to drop the engine and transmission in order to get to the guts of the engine and check/replace the flaps. It's actually a lot easier than it sounds. With practice, you can drop the combo in under an hour.
http://www.914world.com/specs/tech_engdrop1.phpAlso, i don't see why a stock oil cooler wouldn't work for you?
era vulgaris
QUOTE(ash00 @ May 4 2016, 12:23 PM)
If the rod isn't there behind the oil filler then it's doubtful you have flaps. The stock oil cooler is more than adequate for a 2.0 or smaller engine. The problem you're having, if you don't have flaps, is that air isn't getting pushed through your oil cooler, hence the overheating.
Going with an external oil cooler requires a number of modifications to be made. Not just to mount the cooler, but you'll need to run new lines, and fabricate a blanking plate to cover the "hole" that's left where the stock oil cooler was so that you don't loose air going to the 3 and 4 cylinders.
Here are some images that may help you better understand how the cooling system works and how air gets to the stock oil cooler.
era vulgaris
May 4 2016, 11:17 AM
more
era vulgaris
May 4 2016, 11:20 AM
And this is the thermostatic bellows that controls the flaps. Likely missing since it sounds like you don't have flaps.
ash00
May 4 2016, 11:33 AM
Wow, thanks for the great photos! I'm loving this forum already!
Looks like I have a busy weekend ahead of me, but I guess this is one step closer to solving all of the issues of a half-assed restoration. This is why I never trust anybody but myself!
ash00
May 4 2016, 11:45 AM
Well, the news gets better.
I just texted the PO:
"as far as I could see the flaps we permanently closed and thermostat removed. A common warm climate (california) modification to help with cooling"
So...doesn't look like its helping much.
I guess the options are:
1) Source out the necessary hardware to get that thermostat / linkage in place
2) Remove the restriction and open the flaps permanently?
stugray
May 4 2016, 12:00 PM
It Might still be that none of your oil is getting to the Oil Cooler regardless of how the flaps are positioned.
Read the post #11 about the oil pressure relief valve getting stuck.
ash00
May 4 2016, 12:14 PM
I'm going to check this valve as well.
I guess It's not like a thermostat where I can dunk it in hot water to see if it opens. Anyway of testing this valve?
r_towle
May 4 2016, 03:43 PM
If you removed the thermostat, the flaps fall into a default position which provides the best cooling, so I suspect you do not have that condition.
It would help if you took some pictures and posted them here so others could advise you.
Rich
era vulgaris
May 4 2016, 03:55 PM
QUOTE(ash00 @ May 4 2016, 01:45 PM)
You should tell the PO that that is pure misinformation. Removing the thermostat and disabling the flaps will accelerate wear on your engine as it takes longer for the engine to warm up and get to operating temp. There is no benefit to cooling. Once the flaps are open, cooling is the same whether they are fixed in the open position or whether they opened via the thermostat.
It's more likely that he couldn't find a thermostat during the restoration, as it's not a readily available part.
I'm assuming that's a typo about the flaps being closed...or he doesn't know what he's talking about. No one would permanently close the flaps. If he did, that's your problem right there.
ash00
May 4 2016, 04:05 PM
First off, thanks you all for all the help. Its all making sense now.
I'm definitely going to take some pictures after work and hopefully get more feedback.
Just in my walk over to the shop at lunch, I took a peek and couldn't find the oil pressure switch, instead there is a EMPI oil breather kit, which is tapped from the center oil reservoir on the middle of the cylinder bank. The output of that is looped back into the breather box.
The PO was a vintage car racer, so I assumed he knew what he was doing. I can only assume the worst, and after texting him- he said the flaps were closed permanently. I can't trust anymore after everything else that has gone wrong. I'm trying to understand if there is anyway of inspecting visually, other than no flap shaft between the banks. No thermostat either based on pictures, and I found one on Ebay I might get. It just doesn't sound right when I heard that comment that the flaps were closed.
First off, let me get some pictures.
May 4 2016, 04:10 PM
QUOTE(ash00 @ May 4 2016, 03:05 PM)
That explains a lot!
They usually don't care much about longevity or day to day drive-ability. What is good for a race engine is (most of the time) not so good for a street engine.
stugray
May 4 2016, 04:43 PM
If you had a $13 USB Endoscope you could look in through the vanes in the fan and see if your flaps were even installed in the fan housing.
It's nice having a borescope in my toolbox...
Or you could take the fan off and reach in there.
And:
QUOTE(ash00 @ May 4 2016, 04:05 PM)
The oil pressure switch is down through a hole in the engine tins right next to the distributor.
It has nothing to do with the breather box where you pour the oil in.
That port is where the stock pressure switch should be installed.
If he was a racer, he may have extended that port out of the tin where one woudl install a oil pressure
sender.
Does the car have an oil pressure gauge?
It would be good to know what oil pressures you are seeing when it starts and once it gets "too hot".
ash00
May 4 2016, 06:12 PM
Click to view attachmentClick to view attachmentClick to view attachment Here are some quick pics that hopefully will help. I am in the market for a scope, so now I have a reason!
r_towle
May 4 2016, 06:39 PM
Well, it looks like you do not have the flappers as you already confirmed.
I would suggest you pull the motor ( couple of hours the first time) and without having to remove the tranny you can pull all the head tin, replace those flappers, and make sure the rest of the tin is in place.
There are (I bet) more key pieces missing that you will find once you remove the head tin.
TheCabinetmaker
May 4 2016, 07:10 PM
Not the easiest job, but the upper cylinders tin will come off in the car allowing access to install rod and flaps. Afternoon project if you have everything you need. Besides the rod and flaps, there's a spring on the rod, a linkage inside the passenger side of the fan shroud, two retaining tabs and screws for those two empty screw holes on the shroud next to the hole where the rod enters the flap compartment.
ash00
May 5 2016, 08:28 AM
Looks like I need to go into the classifieds and look for those thermostat and flap parts. Are they all the same for engine size (1.7, 2.0)?
rhodyguy
May 5 2016, 09:06 AM
1.7 1.8 2.0, the same thermo assem. I've never seen a BB plumbed in that fashion.
era vulgaris
May 5 2016, 09:34 AM
QUOTE(rhodyguy @ May 5 2016, 11:06 AM)
How is it breathing without some way to vent? I've always seen them either with a vent on the breather, or with a hose run back to the carb air filter.
What's that hose that's going above the center of the engine case? The one zip tied to the throttle cable.
Would also be interested to see a shot of the underside of the engine on the passenger side. Just to verify that the stock oil cooler is still there.
Also, here's a writeup on removing the oil pressure relief valve. It's on the underside of the engine near the oil filter. It looks like a big flat head screw.
http://www.ephotomotion.com/914engine/page08.htmlIt's something you might want to check.
Tangerine Racing sells an improved version of it in case yours is worn out.
http://www.tangerineracing.com/oilpressurerelief.htmI have it installed on my car. Works great.
ash00
May 5 2016, 10:27 AM
Exactly!
I thought the whole point of venting is to vent towards ambient..but that raised the red flag initially.
Im going to have to pull the motor for sure. Lets see if my boss lets me take Friday off.
Things to check:
1) Flaps and positioning: If they are closed, and I can't piece together the hardware to make it adjustable - is it better to just leave them open (increasing warm up time)?
2) Oil pressure switch: Check condition
3) Routing of the EMPI breather
4) Overall inspection of everything
5) Once back in: Adjust timing and check carb jetting/vacuum check
rhodyguy
May 5 2016, 10:35 AM
The foam element in the BB traps the vapors. Oil puddles in the bottom of the box and it drains back to the engine. If your heads have the vent tubes, you can use them as the flow back route for the puddled oil.
ClayPerrine
May 5 2016, 10:41 AM
I have lots of sets of cooling flaps for your motor. If you pay the shipping, I will send you a complete set for free.
But I don't have any thermostats.
stugray
May 5 2016, 11:16 AM
QUOTE(ash00 @ May 5 2016, 08:28 AM)
I believe I have a complete extra set of flapper & thermostat parts.
May 5 2016, 12:13 PM
QUOTE(era vulgaris @ May 5 2016, 08:34 AM)
The breather box is supposed to have a gap on the top lid to allow for venting. There should be a foam piece in the box that traps the oil vapors and lets the oil drain back into the case with the engine off.
ash00
May 5 2016, 12:21 PM
Wow- you guys are incredible! I love how supportive the vintage car community is, like the ones for my bmw 2002's and mini's, as compared to new cars which bash you for modifications that aren't to "their" liking. Cheers to that!
I would be more than happy to purchase the entire flap/thermostat kit from anybody + shipping. Please email me at aashish.dalal@gmail.com.
Thanks!
Cracker
Man. You AC guys make it so complicated...
T
ash00
May 5 2016, 12:23 PM
I have to take a look at the wiring in detail also... just noticed that he wired the electric fuel pump to jumper from the ignition coil +.
I'm probably scratching the surface with the flap issue. Wish me luck!
May 5 2016, 12:36 PM
QUOTE(ash00 @ May 5 2016, 11:23 AM)
Unfortunately not that uncommon ...
This should help:
http://www.914world.com/specs/SirAndyCarbFuelPumpRelay.php
rhodyguy
May 5 2016, 02:06 PM
That is the best way to power your carb pump. The stock pump circuit will work but you may need to change the wire end to spade terminals.
