During the Route 66 Classic run my distributor decided that it had had enough. Fortunately Warren ("Worn") had a spare distributor, which Leamon and some others replaced in the hotel parking lot. The car is running fine. Now I owe Warren a new distributor.
My car is a '73 with FI and points. The distributor from Warren is from a 2.0
I found the chart below on Pelican. Mine (the old one) is 022-905-205 Q. It isn't on the list. From another web site, I guess that 022905205F is the new number for this part?
Some questions:
1) I'm not sure what distributor number I have from Warren. Were there more than one used in 2.0 cars?
2) The advance/retard characteristics are somewhat different amongst the various distributors. Does it matter if I leave in the one from the 2.0?
3) I want to replace the points with a Pertronix electronic ignition. I can't find the part on their web site (the search function just shows "no records found" for the distributor numbers). Do you guys have a suggestion as to which one?
4) If I leave the "incorrect" distributor in the car but replace the points with an electronic ignition, will it matter which distributor I have?
5) Do I need a new coil too?
6) Are there any other things I need to consider before swapping out the points?
Thanks in advance! (or is that in retard?)
