Click to view attachment The thrubolt method,M8.
Click to view attachment http://www.noblefix.com/helicoil/HeliCoil-Tapping-Chart.htmlhttps://www.google.ca/search?q=hss+drill+ro...i_IUA4Ia07TM%3Ahttps://www.google.ca/search?q=thread+repai...cVaBNoQ_AUIBygCThe right way,or,a way that worked,courtesy of a certain Krusty.
Drill out the RH case's 8.2mm hole to 10.2mm to clear the Helicoil or TimeSert.
Using the kit from Helicoil,make extensions to the drill,tap and driver tools.
This means tig welding the STI tapdrill to a 5/16" dia x 4"L drill rod.
Weld another length of drillrod to the STI M8-1.25 tap,3/8" dia x 5"L,grind flats on the end of the drillrod.
Pre-drill M10.2 for STI tap clearance,the RH side of the case thru to the parting line of the cases,do not drill deeper.
You're working within the space between the case and the head,so you will have to drill the RH case's stud hole larger,10.2mm dia,
in stages using progressively longer drill bits,inserting the drill,then attaching the right-angle drill.
Using the welded,extended tapdrill,drill the LH case to a 3X depth,25-30mm 1"-1.2",clearing swarf,use kerosene to lube.
Cleanout with brake cleaner and long 1/8" air nozzle,ensure no chips remains in the hole.
The STI M8-1.25 tap will clear the predrilled M10 hole by .008" 0.2mm,using kerosene,begin tapping the LH case.
Cleanout and apply air,ensuring no swarf remains in the hole,visually.
Having removed the inspection plate,determine there are no chips or raised edge on the gap's mating surface,cleaning.
Install the stainless steel M8-1.25-3x helicoil with the extended tool.
A standard or a custom length M8 stud can now be installed,Loctite recommended for the bottom.
As the stud clearance hole is now 10mm (2mm larger),a spotface should be made on the RH case boss to seat the washer.
A bushing or custom washer is needed for the nut's seat,to fit into the enlarged RH case hole,M10,a lick of sealer,too.
Torque to spec,25Ft-Lbs,then again after cooling from a heat cycle.
Check the gap,that it is indeed closed,the repair effective.
The correct attention to detail and care can get the job done,do not break the drill,taps or driver downhole.
There you have it,the right way,or another way to cinch the 0.002" gap closed,thereby avoiding any bearing wear and nuisance oil drips.
A search for a reference of this type of repair returned no results,tho I vaguely recall an Anderson or other mention of the technique.
Somewhat more invasive than adding a few drops of modern epoxy down hole and works as well.
Those beat up bearing shells or journals look like that because the hp to drive the oil pump and cams is a substantial number.
Loss of clamping pressure allows the oil to escape out the 2-3x enlarged clearance and reduces the oil film thickness at the journal.
A rod bearing that looks worn down to copper has the same cause,contact through the reduced oil cushion and resultant abrasion wear.
Three ways to solve the gap and drip,all done in the car on a hoist.
