SKL1
May 16 2016, 10:28 PM
Been chasing a slow drip from the banjo fitting on top of the "proportioning valve" on the rear bulkhead.
I've replaced the 10mm and 12mm ID washers a couple times to no avail. It is a PITA working in that tight spot but the fitting is as tight as I can get it, but still has a frustrating slow drip...
Any kind of gasket material (like the blue stuff) to smear on the washers to help??
Did I mention I HATE working with brake fluid????
Garland
May 16 2016, 10:44 PM
It's been said before " I wish I would have just done this"
PMB Performance - Pressure Regulator Restoration Service, The only full restoration service on the planet!
PMB 914 World topic linkI also think he has a kit.
Mike Bellis
May 16 2016, 10:55 PM
It may help to anneal the copper washers with a torch to soften them. This will help if the mating surfaces are uneven.
r_towle
May 16 2016, 11:00 PM
Bellis,
Start thread with loads of details of old rotary van please.
