QUOTE(Gearup @ May 27 2016, 11:51 AM)
Flared car running 16 X 8 245 rear tires. Don't know if this is a factor in the responses here. I have been told that I should not run a rear sway bar. Street use car but want it to handle the best in can in the Rocky Mtn. Curvey roads
suggestion and/or inputs. Thanks. Brett
The "no rear bar" applies mostly to autocross for cars that do not have a limited slip differential. It's pretty much a non issue on the big track or street.
For a street car, a rear bar does help to settle the car on curvy roads.
Again, it really only matters if:
- You regularly try to navigate really tight (2nd gear) corners as fast as possible and you:
---- Have enough power to spin the wheels coming out of the corner in 2nd gear
---- Don't have a limited slip differential
A rear bar will tend to lift the inner wheel in the scenario above resulting in a spinning tire instead of going forward.
