He is correct, the IDF and DRLA are the same. The IDA uses a different manifold. The solex's may even use the same manifold. Not 100% sure on that.
Aaron Cox
Apr 7 2005, 12:11 AM
solexes have adpaters.... a tad different...
matt has solex manifolds, weber adpaters, and IDF's....
IDA's are mucho wider than IDF's....
MattR
Apr 7 2005, 12:25 AM
Its on a 912. Solex adapters with IDF adapters and IDF carbs. Whats wrong with that???
SpecialK
Apr 7 2005, 02:41 AM
TB's off of a motorcycle Mike?
Man, your mind never shuts up, does it?
(That's cool though, we'll all be buying your setup(s) someday )
SpecialK
Apr 7 2005, 02:51 AM
Yep, I'd say IDF's.........just a bit shorter than mine.
SLITS
Apr 7 2005, 08:46 AM
They come long and short for Weber/Dels (same mount).
Solex (912/356) mounts are way different.
Since the image shows mounting for Type 4's, you have the Weber/Del setup and the short ones to boot.
JoeSharp
Apr 7 2005, 09:03 AM
Mike: I have that manifold. Carb in the background 48 IDF Joe
KevinP
Apr 7 2005, 10:17 AM
Hey Mueller,
How are you going to separate those TB's? maybe just add another fuel bar or a complete separate manifold. I'm sure this is going to be and intresting project!
Are those TB's off a Yamaha R1? Keep us all posted on this one- I think your gonna have a great payoff!!!
