QUOTE(keely444 @ Jun 26 2016, 01:57 PM)
I want to see if I could tap into a Black / Yellow brake light wire around the pedal area inside the car. I am using a led stripe for the third light and I want to keep everything in the inside of the car. I don't have any wiring diagrams so I was looking for some help. I aleady tested it all out back at the tail light terminal and it all works fine back there. I tried a tap and the light is constant on and no affect when I push the brake pedal. Not to protectant in the electrical areas.
You could be hooking into the wrong side of the switch?
