Best oil, is new oil. Change your oil! Same engine for 40 years, in 4 differant cars. No internal failures.
Later this year that engine will be in its new home (5th), my 72 restoration build. Coming from my 73" 914 Challange Build, that will receive a 1.7 that I'm buillding up a bit.
Every change in season will cause condensation in your engine. I live in Michigan a 4 season state. Engine not run in the winter, so 3 seasons oil change. As a rule I change the oil twice a year, late winter, and early summer. I have only used 20-50, mostly Kendall, generic. Biggest concern has always been heat in the summer for me.
It's a 72 1.7 FI engine, that I have run since 78, in 4 differant cars, using the same electrics, and FI. I drive aggressivly through the gears with almost full throttle till at speed. I have slowed that down a bit over the last 40 years. But in the 70's this engine was the strongest of many that I had, that's why I'v used it. And it's still strong. At the Midwest classic 12 years ago driving through Hell Michigan, I was ask twice if I was running a 2.0, they could not believe it was a 1.7 FI.
I have never had any internal failure, valve adjustments about every 40 thou. Last month I had to replace the distributor due to a worn shaft. Valve tube seals, and oil cooler seals, I replaced one time. And there still holding oil.
Here it is (intakes painted white, and wrong heater hose) the rest stock.
Taken in 1999 In the 73.
Click to view attachmentSide note:
I had a customer in the 90's that drove a 70 ford. He insisted that I not change the filter, only the oil. He said, " the filter is fine, since I change my oil." He was still running with the factory installed Marked filter. Engine ran great.
