Full Version: Help! Please
Beebo Kanelle
I installed a Tangerine Header system - But two little matters still must be addressed:
1) Does anybody have a template or dimensions as to the proper geometry for the shift rod (to clear the headers) - I started to modify mine but I'm afraid I'm making it worse instead of better; and
2) Two of my push rod tubes are now leaking, I must have knocked them loose while installing the exhaust... can they just be pushed back in? or do I need to pull the entire valve train out and redo all the tube o-ring seals?
Thanks in advance...
malcolm2
#2... It has been a while, but IIRC the tubes on the TIV go in and out thru the head. So you could remove the valve cover and push the tube out enough to check or replace the oring.
I am going on memory from 3 years ago, but get your book out or wait on someone that has recently had their hands on a tube>>>> shades.gif
