Full Version: piston ring set 96mm 2 x 2 x 5 Where to buy?
Optimusglen
New rings and a light hone are going in my project, started looking around at my go-to for type 4's and it looks like AA doesnt carry this set. Any recommendations for another vendor?
TheCabinetmaker
You can buy directly from Hastings
Jetsetsurfshop
Call Hasting. I just installed oil rings from them this morning. 96mm too.
Bulldog9
European Motor works sells them too.
Optimusglen
Found em, thanks all!
Mark Henry
KB's are 2mm x 2mm x 4.75mm
Optimusglen
What does KB stand for?
Looks as if my pistons are NPR, and European Motor works sells a set of 2 x 2 x 5 marked as NPR. Couldn't find a set that matches that on Hastings website but I didn't call so maybe they can set me up.
having never done rings, I assume that 4.75 in a 5mm groove is a no-no.
maf914
QUOTE(Optimusglen @ Aug 10 2016, 06:29 AM) *
Mark Henry
QUOTE(Optimusglen @ Aug 10 2016, 10:29 AM) *
That's why I put that up there, everyone who stated Hastings assumed you had KB's, Keith Black pistons.
I knew you had either measured wrong or had a different piston. And yes a 4.75mm ring in a 5mm groove would be bad.
Deves makes a 2 x 2 x 5mm set, you can get them through aircooled.net
http://vwparts.aircooled.net/DEVES-Piston-...es-96-2-2-5.htm
Optimusglen
Most excellent, thank you!
porschetub
QUOTE(Optimusglen @ Aug 10 2016, 12:25 PM) *
Are the ones you need for AA pistons ?,I contacted them some time ago several times and they didn't reply or list the rings I needed,I think they use other makers ring sets.
Edit.....have read above replies,cheers.
TheCabinetmaker
QUOTE(Mark Henry @ Aug 10 2016, 09:45 AM) *
You are exactly right mark. Just assumed. Thanks
porschetub
Good price for a quality ring set,but I seem to remember on many instances engine builders on Pelican having issues with these rings not bedding in properly,or is that just 911 engines... confused24.gif .
Many say genuine or Goetze for the 911,would the 914 be that different?
