| Optimusglen |
Aug 9 2016, 06:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 940 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest
New rings and a light hone are going in my project, started looking around at my go-to for type 4's and it looks like AA doesnt carry this set. Any recommendations for another vendor?
| TheCabinetmaker |
Aug 9 2016, 07:21 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,375 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
You can buy directly from Hastings
| Jetsetsurfshop |
Aug 9 2016, 09:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 815 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Call Hasting. I just installed oil rings from them this morning. 96mm too.
| Bulldog9 |
Aug 9 2016, 09:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 706 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
European Motor works sells them too.
| Optimusglen |
Aug 10 2016, 07:49 AM
Found em, thanks all!
| Mark Henry |
Aug 10 2016, 08:12 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
KB's are 2mm x 2mm x 4.75mm
| Optimusglen |
Aug 10 2016, 08:29 AM
What does KB stand for?
Looks as if my pistons are NPR, and European Motor works sells a set of 2 x 2 x 5 marked as NPR. Couldn't find a set that matches that on Hastings website but I didn't call so maybe they can set me up. having never done rings, I assume that 4.75 in a 5mm groove is a no-no. |
| maf914 |
Aug 10 2016, 08:35 AM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
| Mark Henry |
Aug 10 2016, 08:45 AM
What does KB stand for? Looks as if my pistons are NPR, and European Motor works sells a set of 2 x 2 x 5 marked as NPR. Couldn't find a set that matches that on Hastings website but I didn't call so maybe they can set me up. having never done rings, I assume that 4.75 in a 5mm groove is a no-no. That's why I put that up there, everyone who stated Hastings assumed you had KB's, Keith Black pistons. I knew you had either measured wrong or had a different piston. And yes a 4.75mm ring in a 5mm groove would be bad. Deves makes a 2 x 2 x 5mm set, you can get them through aircooled.net http://vwparts.aircooled.net/DEVES-Piston-...es-96-2-2-5.htm |
| Optimusglen |
Aug 10 2016, 08:51 AM
Most excellent, thank you!
| porschetub |
Aug 10 2016, 02:11 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,078 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
New rings and a light hone are going in my project, started looking around at my go-to for type 4's and it looks like AA doesnt carry this set. Any recommendations for another vendor? Are the ones you need for AA pistons ?,I contacted them some time ago several times and they didn't reply or list the rings I needed,I think they use other makers ring sets. Edit.....have read above replies,cheers. |
| TheCabinetmaker |
Aug 10 2016, 03:19 PM
What does KB stand for? Looks as if my pistons are NPR, and European Motor works sells a set of 2 x 2 x 5 marked as NPR. Couldn't find a set that matches that on Hastings website but I didn't call so maybe they can set me up. having never done rings, I assume that 4.75 in a 5mm groove is a no-no. That's why I put that up there, everyone who stated Hastings assumed you had KB's, Keith Black pistons. I knew you had either measured wrong or had a different piston. And yes a 4.75mm ring in a 5mm groove would be bad. Deves makes a 2 x 2 x 5mm set, you can get them through aircooled.net http://vwparts.aircooled.net/DEVES-Piston-...es-96-2-2-5.htm You are exactly right mark. Just assumed. Thanks |
| porschetub |
Aug 10 2016, 04:05 PM
Good price for a quality ring set,but I seem to remember on many instances engine builders on Pelican having issues with these rings not bedding in properly,or is that just 911 engines... (IMG:style_emoticons/default/confused24.gif) .
Many say genuine or Goetze for the 911,would the 914 be that different? |
Lo-Fi Version | Time is now: 14th April 2026 - 02:26 AM |
