Dutchdriver
Aug 20 2016, 09:52 AM
Hi all, I just changed front and rear brake pads. I've bled the system just in case and also set venting clearance for rear brakes at 0,10 mm. Haynes manual specifies 0,20mm, but online I've read 0,10mm is fine. After a normal drive of around 15 mins, I've noticed both rear rims are hot, front rims arent. Is this normal or do I need to recheck venting clearance?
BillC
Aug 20 2016, 10:12 AM
I would guess that you need to re-set the rear clearance. It sounds like your rear pads are dragging.
rgalla9146
Aug 20 2016, 11:07 AM
E brake cable action and adjustment too.
stugray
Aug 20 2016, 11:23 AM
Three things could cause the rears to drag:
1 - misadjusted venting clearance
2 - Ebrake cable too tight
3 - Old swollen flex lines
Did you replace the flex lines when you did the pads?
The linings can swell and pinch the flow of brake fluid.
Fluid goes in under high pressure, but wont come out leaving the calipers dragging.
relentless
Aug 20 2016, 12:03 PM
Did you set the clearance at the tightest place on the circumference of the disc? There is always a bit of wobble even on new discs.
Dutchdriver
Aug 20 2016, 01:34 PM
Thanks guys. Yep, I did set clearance on the most narrow part, flex lines are only couple months old. I did not check e brake, gonna check that and cleatance tomorrow. I did bleeding after setting clearance, now thinking it was stupid not to recheck the clearance afterwards...
TheCabinetmaker
Aug 20 2016, 02:52 PM
Not stupid, but definitely wrong sequence.
