Thanks, I had read that to work out how to adjust mine. But I didn't read it well enough! The bit I missed is that the inner side adjustment 'bolt' is what the HB lever acts on to apply the handbrake. The outer adjuster provides the firm 'stop' so when in inner piston is moved by the HB, the inner pad puts pressure on the disk which must then flex to put pressure onto the outer pad, then piston, then the adjuster and then the caliper.
So if you don't adjust the inner, all that happens is you need to pull the HB on further.
If you don't adjust the outer, then the disk has to flex further.
Another question then. When the brakes are applied and the pistons move under the pressure of the fluid, is the piston moving against that spring (IYSWIM)?
ETA: I mean the spring that can be seen within the piston.
Graham
QUOTE(BeatNavy @ Aug 26 2016, 02:34 AM)
Yes, it's for the handbrake. This is a great reference for how to adjust from Eric at PMB:
http://www.914world.com/bbs2/index.php?showtopic=90625At the intro he gives a little background on how this works and why. And re-reading it I see he mentions adjusting them "a couple of times a year"
I wonder the last time I did mine...
Could be why I need to pull the handbrake up a notch or two further now when I park in my driveway.
