I have been a 914-6 fan since I first saw one in 1970. The car literally turned my head around, my first view of the 914 was thru the showroom window. I happened to live around the corner from the famous Vasek Polak Porsche dealership. Peering thru the window and seeing the brand new model 914 sitting on the showroom…. side by side with a 908 race car. The two cars were quite similar, mid engine, wheels way out on the corners. I knew at that point the 914 was a very special car. But 914-6 cars were well beyond affordability at the time. I had lusted over the 914-6 for decades and finally was able to afford one in 2002.
This car here is my dream car and I plan to own her forever. My goal was to build a TTOD Autocross car but it turned into my version of a Porsche factory 914-6 hot rod. It took 8 long years to build. This car is no frills and all business is very loud and lightning quick. There are many subtle detailed touches on the car that are the result of my ADD brain endlessly engineering and re-engineering ideas over and over in my head.
From my 914World signature: 1970 914-6 3.6 GT Outlaw
1995-993 3.6 Canadian ROW engine, WebCam RS hydraulic lift camshafts, Cyl heads ports cleaned up and heads milled .010" with a custom multi-angle valve job and new guides, PMS 11 lb lightweight flywheel, fuel injectors blueprinted match flowed by RC engineering, 911Chips Steve Wong custom Motronic chip. 7000 rpm red line.
915 close ratio custom 5 speed w/ G50 LSD Close ratio 1-2-3-4 and 5 od.
Vellios shift kit with WEVO billet shifter
Brembo GTP lightweight full floating brakes, with line lock and brake bias adjust.
19mm MBZ Master Cyl
Bilstein RSR drop spindle struts on mono balls
Hollow torsion bars
Bilstein custom rear shocks with Eibach springs plus helper springs on adjustable perches.
930 steering rack
Turbo Tie rods
Bump steer kit
MSDS 1 3/4" headers, ceramic coated
B&B Muffler Twin 3" tips, custom modified and ceramic coated
HRE311 Fuchs type 3 piece forged centers 17" wheels 7" front on 1" spacers, 9" rears
PMS Fuel cell with custom in tank fuel pump
PMS front mount Setrab oil cooler with Getty Carbon fiber cover
Fully restored media blasted bare metal rotisserie restoration completed 2014, Car is mostly steel with custom one "off" all steel front chin spoiler. One off front custom FG bumper with GT cooler opening. Front and rear trunk lids are Getty Carbon Fiber units.
This original -6 chassis was AutoX champion car in class HI at PCASDR 1999/2000 I purchased the car in Oct 2002. Was already a hotrod when I purchased it.
My build thread:
http://www.914world.com/bbs2/index.php?act...f=2&t=41464
