QUOTE(socal1200r @ Oct 3 2016, 01:15 PM)
QUOTE(Philip W. @ Oct 3 2016, 08:09 AM)
16x 6" front and 16x7" rear with 205/55 16 tires
restored 911 5 lug fuchs
So based on ^ picture, if I keep the stock 15x5.5 Mahles, 205/55s should work fine, so 205/50s are within the realm of the possible!
maybe, depends on offset and backset- mine rubbed so I had to do some fender stretching and still very tight, - in the end ive decided to get 6" width tires and I will be running 205/50-16 which are 8"wide tread, and are 24.1"tall, which is right on for our 914 height - I suppose for your 15" rims you could run 205 but I think 55 to be tall enough or your speedo to be accurate- do a tire calculator on line - you will see how they compare to stock - if I had put 195/55 on my 7" rims I would not have rubbed and been o.k. but like I said, the amount of tread on the ground would be the same as my 6" wide 16" fuchs with 205-50 tires, and better off set, more room on outside- now I could have run 944 turbo wheels and they would be almost 1/2" less to the outside and not rubbed like these did, - oh well, live an learn, - its better to stay with the 6" wide rims , plenty of tread on the ground and tire choices are good on the 16" types.
Phil
The 195/60-15s I have now have a section width of 7.68", and an OD of 24.21". Going to 205/55-15s will give me 8.07" and 23.88", respectively. The OD is close enough that it shouldn't affect the speedo, and the slightly wider footprint hopefully won't present any rubbing issues on the stock 5.5 wide wheels.
