racergreg
Apr 19 2005, 03:13 PM
Does anyone have experience fitting racing seats into a 914? This is for my track-only car, so I don't need to worry about the original seat rails; I will most likely use side mounts and bolt the seat to the floor.
Please let me know the seat make and model that you have successfully used. Thanks!
eeyore
Apr 19 2005, 03:30 PM
Ultra Shield Race Products4 widths. 10 and 20 degree layback. Fairly cheap. Easy to mount since the bottom is solid.
Quite comfortable for street use too. A two hour trip didn't hurt. A friend thought it was just as comfortable as a stock seat.
slivel
Apr 19 2005, 04:05 PM
I put a Cobra Imola 2 in my 914, but to make it work I cut the drivers side cross member out. This isn't a problem in my car as it is full caged and there are no strength issues.
nebreitling
Apr 19 2005, 04:11 PM
got a momo "start" on stock rail sliders in mine. will only fit w/ backpad in if you're short. nice seat, though (thanks, felix!)
campbellcj
Apr 19 2005, 04:49 PM
Cobra Suzuka, sidemounts, bolted to floor (w/ reinforcements), cut-out crossbar.
Series9
Apr 19 2005, 05:06 PM
Corbeau Forza on mounts that I made bolted to the stock locations.
Thorshammer
Apr 19 2005, 06:54 PM
I have a MOMO corse seat, but moved the seat so the right hand side (drivers seat) is against the tunnel and then built mounts for the other three corners. It's nice to be inline with the wheel and pedals, and I can put a same size seat in the right hand side no problem. I do not use a back pad in the race car. I don't think you will either.
Erik Madsen
Randal
Apr 19 2005, 07:15 PM
Kirkey's work great and hold you in.
TimT
Apr 19 2005, 07:18 PM
I have a Momo Nascar in my 914, aluminum mounts bolted to the floor.
joea9146
Apr 20 2005, 05:06 PM
I have 2 Kirkey Seats, The Driver Seat is the Deluxe and is
mounted on rails and sits a little higher than the passenger seat.
The Passenger seat in the Kirkey Intermediate Seat.
Both seats are 17 inches Wide
joea9146
Apr 20 2005, 05:10 PM
Lets see if this Picture is Better :
GTS
Apr 20 2005, 05:46 PM
Well a nice race and competition seat which serves great as a daily driver is our Rallye ST,with openings for 5-6 point harness set up,a period look and crash tested by the DEKRA for the EU.
GTS
Apr 20 2005, 05:47 PM
here istalled in a 914/6 GT replic
for more GTS-classics.com
xsboost90
Apr 20 2005, 07:08 PM
im putting these in, ill let you know how later...
guywan914
Apr 20 2005, 07:19 PM
GTS how about more info on those seats:price, material, mounting, and do the haedrests fit in the 914?
