What race seats fit? |
racergreg |
Apr 19 2005, 03:13 PM
Member Group: Members Posts: 91 Joined: 4-April 05 From: Fullerton, CA Member No.: 3,869 |
Does anyone have experience fitting racing seats into a 914? This is for my track-only car, so I don't need to worry about the original seat rails; I will most likely use side mounts and bolt the seat to the floor.
Please let me know the seat make and model that you have successfully used. Thanks! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
eeyore |
Apr 19 2005, 03:30 PM
Ultra Shield Race Products
4 widths. 10 and 20 degree layback. Fairly cheap. Easy to mount since the bottom is solid. Quite comfortable for street use too. A two hour trip didn't hurt. A friend thought it was just as comfortable as a stock seat. |
slivel |
Apr 19 2005, 04:05 PM
Old car....... older driver Group: Members Posts: 508 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
I put a Cobra Imola 2 in my 914, but to make it work I cut the drivers side cross member out. This isn't a problem in my car as it is full caged and there are no strength issues.
nebreitling |
Apr 19 2005, 04:11 PM
got a momo "start" on stock rail sliders in mine. will only fit w/ backpad in if you're short. nice seat, though (thanks, felix!)
campbellcj |
Apr 19 2005, 04:49 PM
I can't Re Member Group: Members Posts: 4,544 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Cobra Suzuka, sidemounts, bolted to floor (w/ reinforcements), cut-out crossbar.
Series9 |
Apr 19 2005, 05:06 PM
Corbeau Forza on mounts that I made bolted to the stock locations.
Thorshammer |
Apr 19 2005, 06:54 PM
Senior Member Group: Members Posts: 749 Joined: 11-November 03 Member No.: 1,335 |
I have a MOMO corse seat, but moved the seat so the right hand side (drivers seat) is against the tunnel and then built mounts for the other three corners. It's nice to be inline with the wheel and pedals, and I can put a same size seat in the right hand side no problem. I do not use a back pad in the race car. I don't think you will either.
Erik Madsen |
Randal |
Apr 19 2005, 07:15 PM
Kirkey's work great and hold you in.
TimT |
Apr 19 2005, 07:18 PM
I have a Momo Nascar in my 914, aluminum mounts bolted to the floor.
joea9146 |
Apr 20 2005, 05:06 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
I have 2 Kirkey Seats, The Driver Seat is the Deluxe and is
mounted on rails and sits a little higher than the passenger seat. The Passenger seat in the Kirkey Intermediate Seat. Both seats are 17 inches Wide |
joea9146 |
Apr 20 2005, 05:10 PM
Lets see if this Picture is Better :
GTS |
Apr 20 2005, 05:46 PM
Member Group: Members Posts: 64 Joined: 7-October 04 From: South Austin,TX Member No.: 2,903 Region Association: None |
Well a nice race and competition seat which serves great as a daily driver is our Rallye ST,with openings for 5-6 point harness set up,a period look and crash tested by the DEKRA for the EU.
GTS |
Apr 20 2005, 05:47 PM
here istalled in a 914/6 GT replic
for more GTS-classics.com Attached image(s) |
xsboost90 |
Apr 20 2005, 07:08 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
im putting these in, ill let you know how later...
guywan914 |
Apr 20 2005, 07:19 PM
Member Group: Members Posts: 221 Joined: 27-May 04 From: Columbia,CT Member No.: 2,112 |
GTS how about more info on those seats:price, material, mounting, and do the haedrests fit in the 914?
Lo-Fi Version | Time is now: 12th May 2024 - 09:34 PM |
