914Sixer
Oct 29 2016, 05:45 AM
I bought a rebuilt AC Delco rebuilt alternator because it was all I could find a couple of months ago. I checked it when it came and everything seemed to be correct. Well yesterday, I pulled it out to transfer the cover. Got the cover pulled off the old one and went to test fit to the AC Delco before painting. The posts of the newly rebuilt one were over 1/2 " too long. The next thing I saw was the diode plate was sticking up OVER the top of the housing.
The only thing to do was start disassembly of the back of the alternator. Lifted up diode plate and took off the too tall nuts holding the post and replaced them with thinner nuts. This let the diode plate drop below the housing. One problem solved and on to the wrong size bolts. I measured the length of the the ones from the old alternator and got out the cut off wheel and went to work. With the bolts cut off I was able to test fit every thing. What ever happened to plug and play????
87m491
Oct 29 2016, 10:32 AM
I hear you on "all you could find", BTDT. But going with a Delco rebuild for a Porsche and thinking Plug N Play was more Hopium than a real expectation. I'm guessing that is at least half the reason so many folks go with a local rebuilder or do it themselves. I have had good luck with aspwholesale.com. for Bosch alt/starter parts. Also feel you on the delay getting parts bolted up. Often mine sit well past the return period before I get to them and find they are incompatible. Next new years resolution is install parts as they hit my in box!
QUOTE(914Sixer @ Oct 29 2016, 03:45 AM)
I bought a rebuilt AC Delco rebuilt alternator because it was all I could find a couple of months ago. . What ever happened to plug and play????
Downunderman
Oct 29 2016, 12:38 PM
So which AC Delco fits?
jim_hoyland
Oct 29 2016, 02:45 PM
I have a spare that had been rebuilt at a local shop; forgot whether it was originally on my car or I picked it up at the swap meet: from the pictures, does the back appear that it will fit ?
And; is my unit missing the black part (?) in the middle ? Don't know what it is yet
ClayPerrine
Oct 29 2016, 04:12 PM
Every single rebuilt alternator I have purchased for a /4 in the last 30 years had this issue. The reman shop doesn't give a shit about the length of the stud.
And for 30 years I have been cutting off the studs to clear the cover on the back.
Oh.. and don't forget the rubber boot over the positive terminal.
914Sixer
Oct 29 2016, 08:16 PM
Jim,
Your alternator looks to be correct. Clay is also right, DO NOT forget the rubber boot that goes on the red wire. It is a VW boot used on Bugs.
bdstone914
Oct 29 2016, 08:19 PM
I have a local shop that rebuilds them correctly. He has been doing it for 25 years. I have a bunch of cores and can get one rebuilt for $85 plus a core charge of $25.
Dont trust comericial rebuilds.
jim_hoyland
Oct 29 2016, 09:13 PM
QUOTE(914Sixer @ Oct 29 2016, 07:16 PM)
Jim,
Is that black thingy in the middle missing from mine ? And, is this boot suitable ?
Oct 29 2016, 09:31 PM
QUOTE(bdstone914 @ Oct 29 2016, 10:19 PM)
I do the same. They rebuild them on my core. I know what I'm getting back is correct.
ClayPerrine
Nov 1 2016, 12:29 PM
Anyone want to try this?
Bosch 95 amp industrial alternator.From the pictures, it looks like a 914 alternator.
914Sixer
Nov 2 2016, 06:14 PM
Might work, but I think the front plate would need to be fitted with a 914 one.
