Hope Jake, Nathan or Mueller read this as I need to know the amount of space between the IDF manifold, like the ones from CB Performance, where it bolts to the head, up to the trunk lid.
To keep everything consistent let's say from the outside of the IDF manifold where it bolts to the head.
Thanks in advance.
Also a heads up. TWM 45mm throttle bodies do have the same (base) bolt pattern as a Weber 44mm carb. They do not have the same top bolt pattern, so the CB Performance air filter plate has to be modified.
Also to get the base plate to clear the fuel rail a 40mm spacer (more torque?) has to be added, but they didn't mention this when I first talked with tTWM.
Haven't tried as yet to hook up the CB linkage, to make sure it works with the TWM TB, but that's next. The linkage has to move the TB lever down, but I wonder if the Weber carb levers actually move the opposite?
