DNHunt
Jun 25 2003, 07:45 AM
Sorry to bug you guys some more but, I did the compression check wrong. I didn't have the throttle wide open. Here's the new results.
#1 #2 #3 #4
140 140 120 135
After 3cc's of oil
#1 #2 #3 #4
140 140 135 150
Looks like rings in 3 & 4 with 3 the worst.
Dave
Jeff Krieger
Jun 25 2003, 09:05 AM
The Haynes manual states that the normal range for compression pressure for a 2.0 is between 120 and 156 lb/in^2 with a maximum permissible difference of 21 lb/in^2, so you're just within the limits for the latter.
rhodyguy
Jun 25 2003, 09:31 AM
now do the leakdown. are you running syn oil? i'm about the last person to give advice these days. how much oil does the car go through? new plugs are cheap too.
kevin
