Full Version: wiring for modern radio
9fourteen14
hello,
where is the ALWAYS ON POWER SOURCE UNDER THE DASH?
any advice ?
thanx so much
914 luva
IronHillRestorations
Fuses 1-7 are not switched, so you can tap one of those to power the "always on" power lead of your stereo head unit.
mramber
QUOTE(9fourteen14 @ Nov 29 2016, 04:45 PM) *
hello,
any advice ?
thanx so much
914 luva
I went to the back of the fuse block, you can find "always on" power there. Make sure to fuse it as close to where you tap as possible! I'll never forget the day my brother-in-law took me for a ride after he wired a stereo but didn't fuse it and left the wires hanging and not properly insulated. One hard right turn and something shorted out, the entire car was instantly filled with white smoke from the melting plastic!
9fourteen14
QUOTE(Perry Kiehl @ Nov 29 2016, 06:07 PM) *
awesome thanx so much
doing it now.. will let ya know the outcome.
73 914 luva
9fourteen14
QUOTE(9fourteen14 @ Nov 29 2016, 06:16 PM) *
73 914 luva
it works beautiful. i put it on each fuses 1 thru 7 and it works.
and i did put an inline fuse about 6 inches from the radio.
thanx for the tip.
914 luva
