QUOTE(jim_hoyland @ Dec 27 2016, 05:55 PM)
QUOTE(ClayPerrine @ Dec 26 2016, 07:58 PM)
[I also trimmed the 911 key bezel down to fit in the 914.
How did you trim the bezel ? I need to do that.....
1. Made a fixture for my drill press to hold the bezel. A couple of washers that would fit inside and an 8MM bolt.
2. Used tin snips to cut down the bezel close to where I wanted it.
3. Mounted the cut down bezel in the drilll press.
4. Spun it round and round while using progressively finer files.
5. Finished it off with a progression of finer and finer sandpaper.
That's about it. Simple, no need to get fancy.
