Hey you got a car - a '73, terrific year, and possibly a 2.0, even better. You might try giving Porsche a call and asking them to verify your VIN and see if they can tell you the engine and transaxle numbers.
The biggest things on these cars is rust. Before you drop a lot of money into getting it running, I would assess the condition of the chassis as it relates to rust and damage (if any). Read the build threads and you will quickly learn the very common rust issues on these terrific cars. Once you know the extent of rust repair, I am sure there will be some, then you can decide on a plan of attack to correct that and make the chassis a solid platform to start with.
Then turn to getting it running correctly. Address the fuel system like if it has the original plastic fuel lines, get rid of those and replace with stainless steel, have the gas tank boiled out and coated, replace the fuel filters, look for and correct oil leaks, check the cooling system, do a basic tune-up, valve adjustment and establish a base line. Check out the electrical system to make sure everything works and all of the ground straps are clean and tight. No bare wires, wires just dangling in the engine compartment, under the dash, trunks, etc.
Then go over the brake system. New brake lines to the calipers, rebuild the calipers, flush the system, consider a new master cylinder, rotors and pads.
Tires - check the date codes. If old, even if the tread is still good, toss them and get new tires.
Lastly, look at cosmetics inside and out. Any rips in the seats? Get them covered. Any gauges or warning lights not functioning, get that addressed.
That is a general quick overview. These cars are a lot of fun. A few people have been overwhelmed with the work these cars can need because they underestimate the size of the job and tackle way to much at one time. Be methodical and work one project at a time.
Cheers and Best wishes.
