QUOTE(lvnzdrm @ Mar 5 2017, 06:56 PM)
Posting for a friend. He needs the rear shift shaft and swivel joint. His has been welded together and the bushings are missing. Any help is appreciated here is a picture of what he has.
Thanks in advance
Jon
Hey Jon....I think you're mistaken about what you need.
The pin that goes through the bushings IS removable.
It is a tight fit but it will press out.
So.... press it out...replace bushings...carefully press pin back in.
Nothing slides out of the rear shaft. The weld you see is original.
