QUOTE(gspreeman @ Mar 26 2017, 07:15 PM)
Okay, so, I'm not losing my mind. I definitely don't have a fog light switch on the dash. Someone, years ago really hacked the electric system. I found a wire that was spliced into the windshield wiper wire and a few other splices. Where do I connect the switch to? What would the wires look like coming from the fog lights?
Since you seem to know something about 914s, what about my dead low beam on the drivers side? Dirty or worn out headlight switch?
Start by understanding and finding the wires for the fog lights, from the lights backwards. Use the electrical diagrams on this webpage to find the colors and endpoint of the wires.
http://www.pelicanparts.com/914/914_electrical_diagrams.htmStart with the page called "Current Flow Diagram 1974", about halfway down the page. Go through all six pages, they list part names, wire colors and endpoints. Find the fog light wiring, note the wire colors, and start at your fog lights going backwards. When you understand these diagrams, you can fix almost any electrical item in your car. Use a small battery and a test light with probe to make a simple continuity checker. Check each wire as you find it at each end to make sure you are getting current through it. I just got my fog lamps up and running, used a light up amber toggle switch to run them. I rewired them to bypass the lights switch and high beam block, so now I can use them as daytime running lights independent of the headlights at all.
