All correct parts AFAIK
Wide NORMA 54mm filler neck clamp
Collared filler tube sleeve/seal. Not a plain hose
Foam filler neck seal
Foam breather nipple seal
Rubber oil filter console seal with keeper ring
Missing is a flat rubber washer that goes between body of the car and the threaded
nipple at the bottom of the tank......at the right of the pic.
Also missing is the rubber hook grommit that Bob shows, it would slip over a stock
hose
Does anyone have part number for the NORMA 54mm oil filler neck clamp; I've looked at the NORMA website but unable to find the correct width.
Thanks in advance,
Todd
