QUOTE(Dave_Darling @ Apr 7 2017, 04:13 PM)
The 72 would have the early style window regulators. They are more problematic than the later scissor-lift style.
The 72 will not have the reinforcements inside the doors that the 74 does.
The 72 will not have bumper tits; the 74 will have them F&R.
The 72 might have body-colored bumpers or chrome, the 74 would have either black or chrome.
The 72 may have fixed seat belts, or may have the inertia-reel type. The 74 will have inertia-reel belts.
The 72 will have a 1.7 or a non-original engine. The 74 would have either a 1.8 or a 2.0 (or a non-original engine).
The 72 will have the tail-shift transmission. The 74 will have the side-shifter.
The 72 will have silver-dot gauges. The 74 will have black-dot gauges, unless it is an early 74 that was using up the last of the silver-dot gauges.
The 72 will have separate left and right turn signal indicators in the tach. The 74 will have just one for both--or if it has the early gauges, it will have both hooked up so they blink at the same time.
Some of the optional equipment was different. Some of the materials (e.g., seat material pattern, etc.) were different. Different body and interior options were available.
--DD
Thanks Dave, this info is extremely helpful. As a newbie, I took the Pelican Parts buying guide, serial # locator and tech data sheet to see the car under consideration earlier today that was advertised as a 72.
Good news, Bad news.
Good News is that the car was actually a 73 2.0 as per the 47329......Vin #.
Bad news is that it was only 3/4 numbers matching and had serious rust issues. Had to walk away.
