I installed the turbo tie rod kit.
I used the thick washers that came with the kit.
With the tie rod ends cranked all the way in on both sides, I still have visible toe in on both wheels. I thought I'd read that the washers are needed to ensure enough tire rod end thread engagement.
NOTE: I have 911 Boge struts
Should I have left the washers out?
I can't imagine what else it could be but I'd like confirmation from you experienced folks that I do, indeed, need to remove the washers.
Oh, the joys of learning...
Thanks,
Chris
