I am working on my electrical system so its ready when my engine is done. I am testing the headlights and found that the headlights are popping up when pulling the headlight switch but not going down when I push the switch off. Any ideas?
ConeDodger
May 6 2017, 10:36 PM
Did you mess with the adjustment knobs?
mmascari
May 6 2017, 10:39 PM
QUOTE(ConeDodger @ May 6 2017, 09:36 PM)
Yes, if I adjust them back down manually using the knobs then pull the headlight switch again they pop back up. I dont hear the motor when I push the headlight switch in. Weird.
ConeDodger
May 7 2017, 10:53 AM
I have a couple of known good motors from my car (75). If you want them, I work in Santa Clara near the airport.
falcor75
May 7 2017, 11:16 AM
Since its both of them...wouldnt it rather be the switch thats faulty?
ConeDodger
May 7 2017, 11:18 AM
QUOTE(falcor75 @ May 7 2017, 02:16 PM)
Shhhh... I'm trying to get this shit out of my garage!
larryM
May 7 2017, 11:43 AM
Mike -
most likely the wiring on the headlite switch to the relay is goofed up or just has come loose
it's a convoluted setup twixt multiple switches
yo can find good diagrams if you search here or google it
fwiw i recently rewired mine so they only pop up on full ON, not in park position, and rewired my TS so the euro park & individual gage signals both work correctly - took a LOT of hours -
falcor75
May 7 2017, 10:56 PM
QUOTE(ConeDodger @ May 7 2017, 07:18 PM)
Sowwy!
mbseto
May 8 2017, 08:24 AM
If it's been more than 6 hrs, I think you're supposed to call your doctor.
charlesmac
May 8 2017, 10:49 AM
Mine have done this before. The pull knob on the switch was screwed in too far, backed it out a little bit till the headlights went back down.
mmascari
May 8 2017, 01:02 PM
QUOTE(charlesmac @ May 8 2017, 09:49 AM)
Thanks, I will mess with the switch.
