73 years 2.0 pretty much all original/stock
I was driving to work Thursday & when I pulled into the garage and made the pretty tight turns up the ramps I heard/felt a clunk in the rear end -sounded like pass side and seemed to most happen on right turns, at first. Later in the day I felt it at slow speed in a straight, I cant feel it or hear it at higher speeds but assume it's probably happening at speed as well
Search leads me to believe the likely culprit is the CVs or suspension bushings. Is there an easy way to check each to determine which or both or neither is responsible?
thanks for your help
cjl
