Hi all, I went through the posts on valances, but did not find the answer (did learn a lot though so no time wasted)
I have a 73 1.7, the rear Valance under the backbumper has a cut-out as a notch to exit the tailpipe. I still have the old type mufller that has an exit in the middle, where endpipe is attached to, which ends through the rear Valance on the left side.
The NOS endpipe I scored on Ebay (a 021 251 171 M), is shorter then the one that was on the car, so.....it does not reach the nothed out clearance of the Valance. I took off the rearvalance, and started looking around if there are valances that are suitable for this pipe (in the meantime also for another endpipe of course)
Question : There are also rear valances with a hole cut out instead of a notch.
Is the location of that hole the same as the notch in the other type rear valance ?
Or is that located more to the center ?
Thanks for your feedback.
