Got a call from the shop that they can't align the rear right. Problem is that they can't get less than 1/2 inch toe out on that wheel. They want to get it to -1/8 to +1/8.
Of course, the right rear is where I replaced the inner/outer longs and entire wheelhouse. I used a jig (welded up with the driver's side consoles) to get the inner/outer suspension consoles correctly aligned and I thought I had it fairly dialed in - like within 2mm - but I guess I was wrong. Beginner's luck.
They are reluctant to do the alignment saying it's going to pull right no matter what. The shop can't see any way to resolve it short of recutting the consoles or at least ovaling the inner console hole to move it
Posting the pic from 2013 after I had welded up the console to demonstrate where it sits.
They can get the other three wheels OK and they can get the R side camber correct.
Do I tell the shop to dial it in even with that much toe out? Am I going to be I live with this or is it time again?
