QUOTE(Krieger @ Aug 17 2017, 09:42 AM)
Dang, look at the remnants of the worn out parts below the steering shaft!
yep it was shot!, the bearing itself I guess was ok, the plastic inner race was in pieces, - I was ignoring a bit of play that I had for a while, as I don't drive the car that much, I was on my way to the Cars and Coffee and hit a pot hole and the steering jerked and I suddenly had a huge amount of play in every direction and you can see why!- ordered the bearing that morning and put it in the next weekend.-
Just have to be careful when taking the steering apart , keep track of the screws , and disconnect the water lines from the spray bottle, etc- there is a thread somewhere on the step by step- but it was pretty straight forward. you see some metal shavings there from the edge of the outer column housing, it chipped off a bit as I took the retaining clip out. I was worried that the clip might not stay in the groove due to that but so far so good- it went in good and tight.
Phil
